[gdal-dev] A gdal-users mailing list?
Eli Adam
eadam at co.lincoln.or.us
Sat Nov 26 00:39:35 EST 2011
Hermann,
Just a note that this topic has been on the list before,
http://lists.osgeo.org/pipermail/gdal-dev/2010-March/023779.html
Bests, Eli
> Hi all,
> Could it (perhaps) make sense to have a gdal-users mailing list, in analogy
> to grass-users, qgis-users, etc. ?
> I assume that, according to some logic, GDAL/OGR is considered to be a
> library from/for developers, not a GIS application for end-users. On the
> other hand, there are quite some documented utilities around [1], utilised
> by gdal-users like me. Actually, if I compare [1] with [2], I see that my
> "make install" installs many more utilities/scripts than mentioned on the
> GDAL Utilities page.
> Users might have (..hmm..) simple questions that real developers might
> consider to be (..hmm..) not so interesting. gdal-users could be a list
> where experienced users reply to newcomers, with the side-effect of reducing
> some traffic on gdal-dev.
> Hermann
> [1] http://www.gdal.org/gdal_utilities.html
> [2] $ make install
> 1 libtool: install: (...) gdalinfo
> 2 libtool: install: (...) gdal_translate
> 3 libtool: install: (...) gdaladdo
> 4 libtool: install: (...) gdalwarp
> 5 libtool: install: (...) nearblack
> 6 libtool: install: (...) gdalmanage
> 7 libtool: install: (...) gdalenhance
> 8 libtool: install: (...) gdaltransform
> 9 libtool: install: (...) gdaldem
> 10 libtool: install: (...) gdallocationinfo
> 11 libtool: install: (...) gdalsrsinfo
> 12 libtool: install: (...) gdal_contour
> 13 libtool: install: (...) gdaltindex
> 14 libtool: install: (...) gdal_rasterize
> 15 libtool: install: (...) gdal_grid
> 16 libtool: install: (...) ogrinfo
> 17 libtool: install: (...) ogr2ogr
> 18 libtool: install: (...) ogrtindex
> 19 libtool: install: (...) testepsg
> 20 libtool: install: (...) gdalbuildvrt
> 21 libtool: install: (...) scripts/epsg_tr.py
> 22 libtool: install: (...) scripts/esri2wkt.py
> 23 libtool: install: (...) scripts/gcps2vec.py
> 24 libtool: install: (...) scripts/gcps2wld.py
> 25 libtool: install: (...) scripts/gdal2tiles.py
> 26 libtool: install: (...) scripts/gdal2xyz.py
> 27 libtool: install: (...) scripts/gdal_calc.py
> 28 libtool: install: (...) scripts/gdalchksum.py
> 29 libtool: install: (...) scripts/gdal_fillnodata.py
> 30 libtool: install: (...) scripts/gdalident.py
> 31 libtool: install: (...) scripts/gdalimport.py
> 32 libtool: install: (...) scripts/gdal_merge.py
> 33 libtool: install: (...) scripts/gdal_polygonize.py
> 34 libtool: install: (...) scripts/gdal_proximity.py
> 35 libtool: install: (...) scripts/gdal_retile.py
> 36 libtool: install: (...) scripts/gdal_sieve.py
> 37 libtool: install: (...) scripts/mkgraticule.py
> 38 libtool: install: (...) scripts/pct2rgb.py
> 39 libtool: install: (...) scripts/rgb2pct.py
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
