[gdal-dev] OGR SQL, COUNT([DISTINCT] xx) and NULL values
Even Rouault even.rouault at mines-paris.org
Mon Nov 28 15:46:52 EST 2011
Le vendredi 25 novembre 2011 23:14:31, Even Rouault a écrit :
> Hi,
> http://trac.osgeo.org/gdal/ticket/4354 :
> """Currently, OGR SQL considers COUNT(a_column) as a synonym of COUNT(*).
> However the standard mandates that COUNT(a_column) only count non-NULL
> values, whereas COUNT(*) count all rows (after the effect of WHERE clause
> of course). So COUNT(a_column) should not be considered as equivalent to
> COUNT(*) The same applies for COUNT(DISTINCT a_column): it should only
> count unique non-NULL values.
> What is a bit annoying here is that ogr_sql.html says that : "As a special
> case, the COUNT() operator can be given a "*" argument instead of a field
> name which is a short form for count all the records though it would get
> the same result as giving it any of the column names [...]"
> If we fix the current behaviour to be conformant with the standard, it can
> break assumptions made by users. But currently, there's an inconsistency if
> you look at the result of -sql "select sum(foo), count(foo), avg(foo) from
> bar" when there are null values.
> Perhaps only fix that in trunk (the current behaviour existed in 1.7 and
> likely previous versions, not only in 1.8) ? and in the doc, add a note
> about the difference between new and old behaviour ?
Commited in trunk only
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
