[gdal-dev] .ovr files and Lanczos
Eli Adam
eadam at co.lincoln.or.us
Tue Nov 29 12:42:27 EST 2011
Are .ovr files just tifs with a different file extension?
If so, could you use, gdalwarp -tr # # -r lanczos output.ovr?
Eli
On Mon, Nov 28, 2011 at 10:57 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com> wrote:
> Robb,
> Note that the quality is effected by the levels you choose.
> Can you provide a small part of the image where the overview is garbled the
> most.
> On Tue, Nov 29, 2011 at 12:00 PM, Robb Wright <robbkwright at gmail.com> wrote:
>> Thanks Chaitanya. Unfortunately gdaladdo doesn't support the Lanczos
>> resampling type. Lanczos creates - by far - the best looking downsampled
>> images for my type of rasters. What I'm looking for is a way to create
>> pyramid layers/.ovr files using the Lanczos resampling method.
>> Robb
>> On 11/29/2011 12:58 AM, Chaitanya kumar CH wrote:
>> Robb,
>> If you are using gdal version 1.6 or later, you can use the -ro option[1].
>> It opens the tiff file in read-only mode and creates external overview.
>> [1]: http://www.gdal.org/gdaladdo.html
>> On Mon, Nov 28, 2011 at 11:53 PM, Robb Wright <robbkwright at gmail.com>
>> wrote:
>>> I'm working with indexed color types of raster data (charts). The data
>>> is in RGB geotiffs and I'm using gdaladdo to create pyramid layers for them.
>>> Unfortunately, the best method for this raster type available using
>>> gdaladdo is still pretty bad - much of the linework becomes garbled when
>>> viewing the pyramids. The best-looking method that I've been able to come
>>> up with is:
>>> gdaladdo.exe --config COMPRESS_OVERVIEW DEFLATE -r average
>>> The Lanczos algorithm method works beautifully when used with other
>>> programs - but I need to create .ovr files. gdal_retile.py output looks
>>> great - but I can't figure out how to create .ovr files from that output.
>>> Does anybody know of the availability of the Lanczos resampling method
>>> for gdaladdo - or of another way to create .ovr files with Lanczos?
>>> Robb
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
