[gdal-dev] ogr, vrt - connecting to arcsde errors only with srcsql
Duarte Carreira
DCarreira at edia.pt
Mon Oct 3 13:17:25 EDT 2011
Hi there.
I'm having trouble using a SrcSQL tag in a vrt that connects to an ArcSDE feature class.
If I use SrcLayer everything works.
But if I remove SrcLayer, and add a SrcSQL with the simplest of queries (SELECT * FROM USER.TABLE1) I get errors in ogrinfo:
ERROR 1: SQL Expression Parsing Error: syntax error
ERROR 1: SQL statement failed, or returned no layer result:
SELECT * FROM GDBMAN.SREGA_PERIMETROS_REGA
FAILURE:
Unable to open datasource `sde_Regadio_SQL.vrt' with the following drivers.
Any idea why this is?
Thanks,
Duarte
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111003/3f277147/attachment.html
