[gdal-dev] Resquest for comments (RFC 36)
Ivan Lucena
ivan.lucena at pmldnet.com
Mon Oct 3 20:02:21 EDT 2011
Hi All,
RFC 36: http://trac.osgeo.org/gdal/wiki/rfc36_open_by_drivername
The goal of RFC 36 is to save processing time by telling GDALOpen what driver to use, avoiding the driver-probing mechanism (Where all drivers are asked to checked if they recognize the file).
It works by adding the driver name before the file-name as in GDALOpen("hfa:example_file.img").
*It is optional*. It does not invalidate the current simple filename entry that most of the drivers use nor the more complex "filename" string formats used by a few drivers (with things like server-name, port-number, table-name).
It is intended to speed up applications or scripts that need to process a large number of datasets when it already knows what driver to use.
Command line use should not be affect considerably in terms of speed but it adds the option to avoid the wrong driver from taking precedence from the intended one (#3043), ex.:
$ gdalinfo ntif:/autotest/gdrivers/data/rgb.ntf"
If you want to try it, a patch that implements this proposed change is available on ticket 3043 http://trac.osgeo.org/gdal/ticket/3043
Please take a look and send us your comments.
Regards,
Ivan
