Re: [gdal-dev] Re: Resquest for comments (RFC 36)
Ivan Lucena
ivan.lucena at pmldnet.com
Tue Oct 4 06:31:31 EDT 2011
Hi Jukka,
That is a very important concern, you could try the path on your machine so that we can make sure. But I believe that because the functions does not strip the driver name from the oOpenInfo.pszFilename, when it fails and go back to the original code, it will also fails because no driver will recognize a file name like "DRVX:landsatscene.cot". Not even the DRVX driver. In that case GDALOpen will through the same old error.
Regards,
Ivan
> -------Original Message-------
> From: Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Re: Resquest for comments (RFC 36)
> Sent: Oct 04 '11 01:42
> Ivan Lucena <ivan.lucena <at> pmldnet.com> writes:
> > Hi All,
> > RFC 36: http://trac.osgeo.org/gdal/wiki/rfc36_open_by_drivername
> > The goal of RFC 36 is to save processing time by telling GDALOpen what driver
> to use, avoiding the
> > driver-probing mechanism (Where all drivers are asked to checked if they
> recognize the file).
> You can add to the motivation of RFC also the case when a file format is
> supported by several drivers. I do not know if there are others than JPEG2000
> but for that GDAL has JPEG2000, JP2KAK, JP2ECW, JP2MrSID and JP2OpenJPEG
> drivers. If several drivers are configured the only way to control which one is
> used is to use GDAL_SKIP. Being able to tell which driver to use instead of
> which one(s) not to use feels much better for me.
> I can easily imagine that someone making benchmark with different GDAL JPEG2000
> drivers could get totally wrong results if the new driver:file opening system
> for some reason fails and GDAL takes automatically the first capable JPEG2000
> driver from the list without warning the user. Wouldn't it be better to throw an
> error by default?
> -Jukka Rahkonen-
> gdal-dev mailing list
