[gdal-dev] Re: gdal_merge.py - Missing images
Jay L. jzl5325 at psu.edu
Fri Oct 7 12:27:04 EDT 2011
GIving gdalwarp a try now and slapping my forehead for not thinking to try a
.vrt.  Thanks for the nudge Jeff.
On Fri, Oct 7, 2011 at 12:25 PM, Jeff Ruby <jgr007 at gmail.com> wrote:
> You might try building a vrt file first and then converting that.
> gdalbuildvrt merge.vrt *.tif
>  -or just merge the original IMGs-
> gdalbuildvrt merge.vrt *.img
> -then-
> gdal_translate <your options> merge.vrt output.tif
> > Message: 4
> > Date: Fri, 7 Oct 2011 11:42:52 -0400
> > From: "Jay L." <jzl5325 at psu.edu>
> > Subject: [gdal-dev] Fwd: gdal_merge.py - Missing images - sans
> > To: gdal-dev at lists.osgeo.org
> > Message-ID:
> CA+bfmPsVpqKPSdOWvuvnG8vR9okKpHBRAKvznCQ3fRbBuGjDVQ at mail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Sent with an example attachment, which is awaiting approval.  Here is the
> > mail without attachement.
> > I have 8 large Gtiffs which I am trying to mosaic.  Tiffs were created
> from
> > .IMG files downloaded from PDS.  I converted to tif using:
> >        gdal_translate -of GTiff -scale -co "TILED=YES" -co
> "COMPRESS=JPEG"
> > <input>
> > The format conversion is working without a problem.  Gdalinfo is
> reporting
> > the correct NDV and projection information.  Viewing each tif also
> returns
> > the expected raster iamge.  So far, so good.
> > I then use:
> >        gdal_merge.py -o wacmos.tif -of GTiff -v --optfile tiff_list.txt
> > Six of the eight tiles are added to the mosaic correctly.  Varying the
> order
> > in the list, or using *.tif does not change the output.  It is always the
> > same two images which are missing.  Watching the verbose output, it looks
> > like the images are mosaicing correctly.  What would cause these images
> to
> > be merged as totally black tiles?
> > Thanks for any insight,
> > Jay
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111007/0610dfbd/attachment.html
