[gdal-dev] CMake for GDAL
    Jayesh Chaudhary
    aashishcy at gmail.com
    Fri Oct  7 14:14:21 EDT 2011
Hi All,
First of all, many thanks to Howard for introducing me. I have been using
GDAL for long time and used it successfully in various projects
No need to say that CMake has been adopted by various open source and
commercial projects. CMake itself is open source with a very flexible
licensing and is very active project (just this week 2.8.6 has been
released) (http://www.vtk.org/Wiki/CMake_Projects)
I personally felt that GDAL can be benefited by using CMake. Once done, It
 will make it easier to add new modules to GDAL and save bunch of time
writing custom build files for various platforms. Also if desired, can be
coupled with CTEST and CDASH for testing.
It is good to see that people are supporting the idea. To know more about
CMake please visit http://cmake.org/cmake/project/about.html. Please feel
free to contact us if you have any questions / concerns.
Thanks,
Aashish
On Thu, Oct 6, 2011 at 3:38 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> It sounds great indeed!
> In particular I am interested in improving detection of netcdf library
> and its various incarnations and support libs (v3, v4, HDF4, HDF5,
> zlib, szip), which would make things much easier for our improvements
> to the netcdf driver.
> I'd definitely like to help on that aspect of the cmake script,
> although I don't have experience in building cmake configuration
> scripts.
> regards,
> Etienne
> On Thu, Oct 6, 2011 at 1:04 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> > All,
> > There has been a couple of efforts started to bring a CMake build
> configuration to GDAL, but they haven't taken off because of lack of
> momentum and project buy in. For those who don't know, CMake is a sort of
> meta-builder, kind of like an autotools that generates many project Makefile
> layouts. CMake can generate MSVC project files, MSVC Makefiles, XCode,
> Eclipse, GNU Makefile, etc. You have one CMake configuration that specifies
> the changeable bits, and CMake takes care of the rest to generate the
> project type that you desire. CMake can even stack project builds together,
> so the the CMake configuration of GDAL can use the CMake configuration of
> GeoTIFF.
> > GDAL currently has hand-rolled MSVC Makefiles, an combination hand-rolled
> libtool project (that we generally tell people not to use), and hand-rolled
> MSVC project files.  Adding another build system into our source tree is not
> going to add that much more complexity to what we already have, and I would
> like to propose that we integrate the CMake build for GDAL efforts that have
> been happening outside of the project inside our source tree.  If the effort
> takes off, maybe we can eliminate some of these hand-rolled efforts, but at
> this time, the CMake effort will just be supplementary to the existing build
> systems that already exist in GDAL.
> > I am willing to manage this effort, and I expect contribution from a
> couple of folks who have been itching for it. One of these key individuals
> is someone I met at #foss4g, Aashish Chaudhary, who is a software engineer
> at Kitware, the proprietors of CMake.  Aashish is a GDAL user, and a CMake
> configuration, with full detection capabilities for the myriad of external
> dependencies that GDAL can take advantage of would be a big, cross-platform
> build win for him. Aashish has volunteered to do the bulk of the integration
> work of the existing, external CMake configuration into the source tree, and
> having quick access to CMake developers who can answer any questions that
> might come up about GDAL's complex build layout will also be helpful.
>  Workflow-wise, I would like to give Aashish sandbox access so he can start
> working on the tree there, and then I'll take care of moving things into the
> main trunk as they mature.  Once things are integrated, it would make lots
> of sense to give Aashish proper commit access provided he looks like he'll
> be able to stick around and help maintain things -- although once everything
> is standing, the maintenance should be limited.
> > tl;dr summary. Aashish Chaudhary and myself are going to bootstrap
> incorporating CMake configuration into GDAL. We hope to have things done by
> the 1.9 release. This is your notice of that fact.
> > Thanks,
> > Howard_______________________________________________
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111007/0e02049a/attachment.html
