[gdal-dev] Slow to write a hfa(erdas img) file?
rrrrssss00
wyzwyz969 at 163.com
Sun Oct 9 22:45:56 EDT 2011
need to write a big img file(2GB) from a source file(the source is also img).
it takes about 10mins , but if i write in tif or pix format, it takes much
less time (about 2min)
i tried to use the gdal_translate.exe to do the same thing , the result is
almost the same,write in img format is slow...
so , my question is : is there something wrong in the code of writing img
format? or how can i speed up the progress of writing img file
thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Slow-to-write-a-hfa-erdas-img-file-tp6875603p6875603.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
