[gdal-dev] GTiff INTERLEAVE=BAND
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Oct 13 00:56:14 EDT 2011
Jay,
Can you provide a small sample image that shows this problem?
On Thu, Oct 13, 2011 at 7:35 AM, Jay L. <jzl5325 at psu.edu> wrote:
> I have a series of raster images (GTiff) that are causing ArcMap10 to hang.
> After trying a number of different things (32bit to 8bit, translate to
> another format, compression, tiling, etc.) I suspect that the issue could be
> with the interleave. Gdalinfo shows that INTERLEAVE=BAND. The GTiff driver
> suggests that some programs can not handle band and require pixel. I have
> tried the following, but have been unable to get interleave set to pixel.
> Ideas?
> gdal_translate -of GTiff -ot Byte -co COMPRESS=LZW -co INTERLEAVE=PIXEL
> <input.tif> <output.tif>
> Thanks,
> Jay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111013/04c66c0a/attachment.html
