[gdal-dev] proposal for a new GDAL/OGR utility app: gdalsrsinfo
Frank Warmerdam
warmerdam at pobox.com
Sun Oct 16 21:06:28 EDT 2011
On Sun, Oct 16, 2011 at 6:02 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> I'll look into testepsg, I thought it was only for EPSG codes (guess I
> was wrong). I also overlooked it because it is not in the GDAL
> utilities page.
Etienne,
The most accurate part of the utilities name is "test". It is not
in the utilities page because it is not a supported utility. It
was really just for me to do testing.
> Perhaps I can combine testepsg with gdalsrsinfo ?
I would imagine gdalsrsinfo superceding testepsg.
The gdaltransform utility already does the transformation work
done by testepsg.
I'm ok with you adding gdalsrsinfo as a supported utility.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
