[gdal-dev] Confused about datum transformations
Kyle Shannon
KShannon at gcs-research.com
Tue Oct 18 10:41:17 EDT 2011
Did you compile gdal yourself, or use a pre-built package. It is also possible GDAL_DATA environment variable isn’t set.
kss
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of dev4cx4m9z at snkmail.com
Sent: Tuesday, October 18, 2011 4:12 AM
To: gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Confused about datum transformations
I’m not sure the code will help too much, but here are the relevant code fragments. I’m using a hand crafted VB.net wrapper which explains some of the syntax
Private WGS84SRS As New OGRSpatialReference ' Coordinate system in WGS84
Private MapSRS As OGRSpatialReference ' Coordinate system of map
Private ctWGS84toMap As OGRCoordinateTransformation ' Coordinate transform from WGS84 to map
With WGS84SRS
GDALError = .SetProjCS("WGS84 Datum")
Debug.Assert(GDALError = OGRError.OGRERR_NONE, GetLastErrorMsg())
GDALError = .SetWellKnownGeogCS("WGS84") ' Define WGS84 coordinate system
End With
With MapSRS
GDALError = .SetProjCS("Map coordinate system")
GDALError = .ImportFromEPSG(3577)
End With
ctWGS84toMap = GDAL.CreateCoordinateTransformation(WGS84SRS, MapSRS) ' Create a coordinate transformation - WGS84 to map
Debug.Assert(ctWGS84toMap IsNot Nothing, GetLastErrorMsg())
Marc,
Can you provide the code leading to the error?
On Tue, Oct 18, 2011 at 1:21 PM, Marc Hillman <dev4cx4m9z at snkmail.com<mailto:dev4cx4m9z at snkmail.com>> wrote:
I have a GIS database, and all data is stored in WGS84 datum. I have developed an application using GDAL, and I now need to translate my WGS84 coordinates to several different datums, depending what map is loaded. I seem to be going around in circles, and need a nudge in the right direction. I am defining an OGRSpatialReference for each datum (WGS84 and current map) and then attempting to create an OGRCoordinateTransformation for the transformation.. This last step fails with a PROJ.4 error (“No PROJ.4 translation for destination SRS, coordinate transformation initialization failed”
My question is - Do I need PROJ.4 to do the translation? Can I not just use ImportFromWKT to define my OGRSpatialReference? If so, is there a nice canned list of all the WKT somewhere? I’m keen to avoid PROJ.4 if possible as I’m not sure I can build it.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
No virus found in this message.
Checked by AVG - www.avg.com<http://www.avg.com>
Version: 2012.0.1831 / Virus Database: 2092/4558 - Release Date: 10/17/11
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111018/c2ba67df/attachment.html
