[gdal-dev] proposed changes to netcdf export behaviour (perhaps
RFC)
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 19 01:34:19 EDT 2011
On 11-10-18 10:19 PM, Etienne Tourigny wrote:
> Hi Frank,
> On Tue, Oct 18, 2011 at 7:22 PM, Frank Warmerdam<warmerdam at pobox.com> wrote:
>> On Tue, Oct 18, 2011 at 1:10 PM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>>> 2) Change to a default south-up orientation for NetCDF data
>> Etienne,
>> Could you expand on this a bit? In particular I'm wondering if:
>> 1) Is a south-up file represented as south up to GDAL applications?
>> That is, will geotransform[5] be negative or positive?
> Files created by the driver have a negative pixel height
> (geotransform[5]) when opened with GDAL , so I guess that means it
> looks like it is north up.
> When the driver opens a south-up file, it has to invert the y axis
> upon import to make it compatible with GDAL's data model.
> For example, a gtiff landsat that has the following geo info:
> Origin = (625970.000000000000000,8981830.000000000000000)
> Pixel Size = (30.000000000000000,-30.000000000000000)
> Which is the same when translated to netcdf and the netcdf is read by GDAL.\
Etienne,
OK, it seems that to applications the change to producing
bottom-up files will not be particularly disruptive.
> For what it gives, here are some numbers for gdal_translate on a test
> dataset (22239 x 33359 INT) . The netcdf creation takes longer than
> gtiff, but the difference between south-up and north-up is small.
> gtiff-> gtiff
> real 0m34.251s
> user 0m1.550s
> sys 0m3.710s
> gtiff->netcdf (BOTTOM_UP=YES)
> real 1m3.869s
> user 0m2.520s
> sys 0m5.300s
> gtiff->netcdf (BOTTOM_UP=NO)
> real 1m35.077s
> user 0m3.050s
> sys 0m6.150s
> gtiff->netcdf (driver in svn trunk, north-up)
> real 2m4.186s
> user 0m5.110s
> sys 0m7.130s
I'm a bit confused about the above. How are the "driver in svn trunk,
north-up" case and the "BOTTOM_UP=YES" case different? Why is
"BOTTOM_UP=NO" case slower than "BOTTOM_UP_YES" case?
In any event, at least for this case the differences aren't devastating
and there are options to control what is done. I am supportive of changes
that produce a more interoperable result.
As PSC chair I will not be offended if you proceed with netcdf changes
*without* a formal RFC type vote on the changes. The changes are fixing
bugs and don't cause real backward compatability issues and I'm willing to
treat you as the authority/owner for the driver.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush | Geospatial Software Developer
