[gdal-dev] DTED Elevations with Java and gdal
Roger Viton wsureshoot at fastmail.fm
Wed Oct 19 16:23:39 EDT 2011
There have been other threads on this topic.  The threads seem to die with no
clear solution presented.
Does anyone have a Java example on how to get elevations from a DTED file?
org.gdal.gdal.Dataset dataset = org.gdal.gdal.gdal.Open(<some dted file>,
org.gdal.gdalconst.gdalconst.GA_ReadOnly);
With an x y point how can the elevation be derived?
We have been able to run GDALtest.java against a DTED file with no problem.
There does not seem to be any reference to any elevation in DTEDtest.java
Just want to get the elevation at a point.
Thanks,
Roger
View this message in context: http://osgeo-org.1803224.n2.nabble.com/DTED-Elevations-with-Java-and-gdal-tp6910385p6910385.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
