[gdal-dev] ReadAsArray with Windows 7
Tamas Szekeres
szekerest at gmail.com
Fri Oct 21 14:49:07 EDT 2011
2011/10/21 Frank Warmerdam <warmerdam at pobox.com>
> If the problem with your script persists when using the OSGeo4W
> python environment then I should be able to reproduce it with a
> suitable bug report. If it does not happen with OSGeo4W then
> the issue likely relates to Tamas's use of SWIG version for the
> python bindings, or possibly a mismatch between the version of
> Python he built for, and the version you are running.
Frank,
BTW: The daily builds at http://www.gisinternals.com/sdk/ always re-generate
the python bindings from the interface files. Is this something that makes
the python bindings more fragile compared to the pre-generated version of
the SWIG output hosted in GDAL SVN? However we may often find that the SWIG
output doesn't always updated when the interface is changing.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111021/352413d8/attachment-0001.html
