[gdal-dev] Still Confused about datum transformations
dev4cx4m9z at snkmail.com
Sat Oct 22 01:47:43 EDT 2011
I have received many useful suggestions, but I am still struggling with what
should be a simple problem. I am trying to translate a series of lat/lon
coordinates in WGS84 coordinates to lat/lon coordinates for my map (AGD66).
The code is below, and seems to mirror sample code in the GDAL tutorials.
When I create the coordinate transform, I get error message "No PROJ.4
translation for source SRS, coordinate transformation initialization
failed".
PROJ.dll is in the right place, and GDAL_DATA and PROJ_LIB are correctly
defined. I don't think the error is here because when I put illegal
parameters (e.g. EPSG:111111) it throws an exception.
I have noticed that when I add a projection to the SRS it seems to help, but
I'm not up to that yet. All I want to do is transform from one datum to
another (in code). Can anyone see the simple mistake I must be making?
Dim WGS84SRS As New OGRSpatialReference ' Coordinate system in
WGS84
Dim MapSRS As New OGRSpatialReference ' Coordinate system of
map
Dim ctWGS84toMap As New OGRCoordinateTransformation '
Coordinate transform from WGS84 to map
Dim WGS84WKT As String, MapWKT As String
With WGS84SRS
GDALError = .SetProjCS("WGS84 Datum")
Debug.Assert(GDALError = OGRError.OGRERR_NONE,
GetLastErrorMsg())
GDALError = .SetWellKnownGeogCS("WGS84") ' Define WGS84
coordinate system
GetLastErrorMsg())
WGS84WKT = .ExportToWkt
End With
With MapSRS
GDALError = .SetProjCS("Map Datum")
GetLastErrorMsg())
GDALError = .SetWellKnownGeogCS("EPSG:4202") '
Australian Geodetic 1966
GetLastErrorMsg())
MapWKT = .ExportToWkt
End With
ctWGS84toMap = GDAL.CreateCoordinateTransformation(WGS84SRS, MapSRS)
' Create a coordinate transformation - WGS84 to map
WGS84WKT = "PROJCS["WGS84 Datum",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],A
UTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG",
"4326"]]]"
MapWKT = "PROJCS["Map
Datum",GEOGCS["AGD66",DATUM["Australian_Geodetic_Datum_1966",SPHEROID["Austr
alian National
Spheroid",6378160,298.25,AUTHORITY["EPSG","7003"]],TOWGS84[-117.808,-51.536,
137.784,0.303,0.446,0.234,-0.29],AUTHORITY["EPSG","6202"]],PRIMEM["Greenwich
",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EP
SG","9122"]],AUTHORITY["EPSG","4202"]]]"
_______________________________________
Marc Hillman, Melbourne, Australia
http://users.tpg.com.au/users/mhillman/
marc .hillman @ t p g . c o m . a u
Eagles may soar, but weasels don't get sucked into jet engines.
Early bird gets the worm, but the second mouse gets the cheese.
If Barbie is so popular, why do you have to buy her friends?
All those who believe in psychokinesis, raise my hand.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111022/af281b15/attachment.html
