[gdal-dev] Re: Gdal_translate, question from an amateur.
joolek joolek.o at gmail.com
Sun Oct 23 04:53:43 EDT 2011
Hi me again...,
Would it be actually possible to convert all the 255 255 255 into 254 254
254?
Is this is the command to do so: gdal_translate -scale 0 254 0 255 <input>
<output>
Thank you in advance for your time,
J
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921658.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
