[gdal-dev] Re: 254 into 255
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Oct 27 04:58:53 EDT 2011
J,
A vrt file[1] can implement your requirements. It can create a 'lookup
table' to translate your pixel values.
Start by running gdalbuildvrt on your raster file and modify it to contain
the LUT element. It will look something like this:
<VRTDataset rasterXSize="512" rasterYSize="512">
<VRTRasterBand dataType="Byte" band="1">
<ComplexSource>
<SourceFilename relativeToVRT="1">utm.tif</SourceFilename>
<SourceBand>1</SourceBand>
<ScaleOffset>0</ScaleOffset>
<ScaleRatio>1</ScaleRatio>
<LUT>0:0,253:253,254:255</LUT>
<SrcRect xOff="0" yOff="0" xSize="512" ySize="512"/>
<DstRect xOff="0" yOff="0" xSize="512" ySize="512"/>
</ComplexSource>
</VRTRasterBand>
<VRTRasterBand dataType="Byte" band="2">
<ComplexSource>
<SourceBand>2</SourceBand>
</ComplexSource>
</VRTRasterBand>
<VRTRasterBand dataType="Byte" band="3">
<ComplexSource>
<SourceBand>3</SourceBand>
</ComplexSource>
</VRTRasterBand>
</VRTDataset>
The LUT element is the key here. It tells the VRT driver to keep the values
from 0 to 253 as they are and change 254 to 255.
Remember to replace the appropriate parts.
[1]: http://www.gdal.org/gdal_vrttut.html
On Thu, Oct 27, 2011 at 12:40 PM, joolek <joolek.o at gmail.com> wrote:
> Yes, this is exactly what I am struggling to do. Gdal is so powerful - but
> I can't get it working.
> J
> On 26 Oct 2011, at 17:10, "Chaitanya kumar CH [via OSGeo.org]"<[hidden
> email] <http://user/SendEmail.jtp?type=node&node=6935299&i=0>> wrote:
> Do you want to convert just the pixels with the values (254,254,254)?
> On Wed, Oct 26, 2011 at 9:33 PM, joolek <[hidden email]<http://user/SendEmail.jtp?type=node&node=6933215&i=0>
> > wrote:
>> Hi I basically want to convert all the 254 254 254 into 255 255 255... is
>> this possible?
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/254-into-255-tp6931988p6933182.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=6933215&i=1>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
> [hidden email] <http://user/SendEmail.jtp?type=node&node=6933215&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/254-into-255-tp6931988p6933215.html
> To unsubscribe from 254 into 255, click here.
> View this message in context: Re: 254 into 255<http://osgeo-org.1803224.n2.nabble.com/254-into-255-tp6931988p6935299.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1803224.n2.nabble.com/GDAL-Dev-f2022644.html>at Nabble.com.
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111027/99e57894/attachment.html
