[gdal-dev] Translating files with a external mask file
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 27 12:48:07 EDT 2011
On Thu, Oct 27, 2011 at 8:14 AM, Travis Kirstine
<traviskirstine at gmail.com> wrote:
> I have a rgb geotiff with a external mask file
> rgb_withmaskfile.tif.msk, I would like to convert the files to a
> compressed GeoTiff using a command simalar to the one below. This
> command will generate a illegal band # error
> gdal_translate rgb_withmaskfile.tif results.tif -b 1 -b 2 -b 3 -mask 4
> -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR --config
> GDAL_TIFF_INTERNAL_MASK YES
Travis,
Is the mask really band 4? I presume the mask (from the .msk file)
is not treated as a regular band of the source file and cannot be
referenced as such. I would hope that gdal_translate would
automatically try to translate the associated mask though I must
confess I haven't tried this myself. If it does not then please file a
ticket.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
