[gdal-dev] Re: 254 into 255
Hermann Peifer
peifer at gmx.eu
Fri Oct 28 02:52:04 EDT 2011
On 27/10/2011 14:48, Chaitanya kumar CH wrote:
> However it [gdalbuildvrt] doesn't support complex sources..
Chaitanya, could you perhaps elaborate on the above statement?
joolek,
About the batch-processing of 3000 files: in my
Linux/Bash/GDAL-from-trunk environment, I would do something like
indicated below.
Hope this helps, Hermann
for f in path/to/mytiffs/*.tif; do
gdal_translate -of vrt $f /dev/stdout |
awk '
BEGIN { lut = "<LUT>0:0,253:253,254:255</LUT>" }
{ gsub(/SimpleSource>/, "ComplexSource>") }
$1 == "</ComplexSource>" { $0 = lut ORS $0 }
{ print }' > tmp.vrt
gdal_translate tmp.vrt ${f%.tif}_modified.tif
done
