[gdal-dev] Renaming a column's name in a Shapefile
António Rocha
antonio.rocha at deimos.com.pt
Fri Oct 28 08:38:43 EDT 2011
Hi Ralf
Thanks for the feedback but it did not work.
I tried:
ogr2ogr -f "esri shapefile" -sql "SELECT ele, time AS t,
magvar,geoidheigh, name, cmt, desc, src FROM GPS_Project" new.shp
GPS_Project.shp
And I got:
ERROR 1: SQL Expression Parsing Error: syntax error
Even I tried:
ogr2ogr -f "esri shapefile" -sql "SELECT ele, magvar,geoidheigh, name,
cmt, desc, src FROM GPS_Project" new.shp GPS_Project.shp
And I got:
Any other suggestion?
Thanks
Antonio
Ralf Suhr wrote:
> ogr2ogr -f "esri shapefile" -sql "SELECT ele, time AS t, magvar,
> geoidheigh, name, cmt, desc, src FROM GPS_Project" new.shp GPS_Project.shp
> Gr
> Ralf
> On Freitag 28 Oktober 2011 13:54:37 António Rocha wrote:
>> ogr2ogr -sql "SELECT [ele AS ele, time AS t, magvar AS magvar,
>> geoidheigh AS geoidheigh, name AS name, cmt AS cmt, desc_ AS desc_, src
>> AS src] FROM GPS_Project.shp", new.shp GPS_Project.shp
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6582 (20111028) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
