[gdal-dev] Generate a KML-overlay from a Geotiff file
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Oct 28 09:13:13 EDT 2011
Kat,
Please provide the whole command you used and the output of gdalinfo on your
input file.
On Fri, Oct 28, 2011 at 4:34 PM, katrin eggert
<katrineggert1980 at gmail.com>wrote:
> Hi
> I have used gdal2tile.py like this
> python gdal2tile.py -k [input] [output] and the tiels that are generated
> are nothing to do with the input image. It has changed the image by almost
> plotting random values pixels.
> Is there any limitation regarding inpu timage (e.g. it must be integer or
> something like this)?
> Thanks
> Kat
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111028/444c5ca1/attachment.html
