[gdal-dev] Trouble using gdal_rasterize
guillaume huby
guillaume.huby.lists at gmail.com
Fri Oct 28 11:29:01 EDT 2011
Hello,
I am using Gdal 1.8.1 (gdalinfo --version -> GDAL 1.8.1, released
2011/07/09).
I used gdal_rasterize to burn some tif file with values from a shapefile:
> gdal_rasterize -a ID -l vector_test vector_test.shp test_out.tif
My tif file contains a unique layer of type UInt32.
The shape files contains an ID column with four features with ID 28021201,
28021202, 28021203 and 28021204.
But test_out.tif is not burned correctly it has :
- 28021200 where 28021201 is expected;
- 28021204 where 28021203 is expected;
- others values are OK.
I can provide sample files if needed.
Is there something I missuse in my command line or is it a normal issue ?
Thanks for your replies.
Best regards,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111028/446733d3/attachment.html
