[gdal-dev] Re: Using a gdal generated tiff to generate DEM
tiles - losing registration
Iain
iainmalcolm1 at googlemail.com
Mon Oct 31 06:43:57 EDT 2011
That might be the answer - or at least part of it, I still get brain fade
trying to work through projections and projection conversion.
I'll try and think this bit through again!
Here's the gdalinfo from the input file :
Driver: GTiff/GeoTIFF
Files: brw.tif
Size is 48243, 78372
Coordinate System is:
PROJCS["unnamed",
GEOGCS["unnamed ellipse",
DATUM["unknown",
SPHEROID["unnamed",6378137,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-1224560.781847173348069,8625918.873687559738755)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-1224560.782, 8625918.874) ( 11d 0'1.50"W, 61d 0'1.50"N)
Lower Left (-1224560.782, 6274758.874) ( 11d 0'1.50"W, 48d59'57.82"N)
Upper Right ( 222729.218, 8625918.874) ( 2d 0'2.92"E, 61d 0'1.50"N)
Lower Right ( 222729.218, 6274758.874) ( 2d 0'2.92"E, 48d59'57.82"N)
Center ( -500915.782, 7450338.874) ( 4d29'59.29"W, 55d27'11.78"N)
Band 1 Block=256x256 Type=Int16, ColorInterp=Gray
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-a-gdal-generated-tiff-to-generate-DEM-tiles-losing-registration-tp6946188p6947684.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
