[gdal-dev] Failed to initialize PROJ.4 with ...
Ralf Suhr Ralf.Suhr at itc-halle.de
Thu Sep 1 06:46:58 EDT 2011
Hi Marco,
it's look like only a typo. Put a space between +proj=merc +a=6378137
Gr
Ralf
On Donnerstag 01 September 2011 12:32:27 Marco Scheuble wrote:
> Hi all,
> I got following error-message while using gdalwarp:
> ERROR 6: Failed to initialize PROJ.4 with `+proj=merc+a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m+nadgri... at null
> +wktext  +no_defs'.
> Situation:
> I've installed GDAL 1.4.4, because the CentOS on the server wouldn't take
> any later version.
> GDAL 1.4.4 doesn't support EPSG:900913, so I added the following lines to
> 'cubewerx_extra.wkt':
> # EPSG:900913
> 900913,PROJCS["Google Maps Global
> Mercator",GEOGCS["WGS84",DATUM["WGS_1984",SPHEROID["WGS84",6378137,298.2572
> 23563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich
> ",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["
> EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_2SP"],PARAMET
> ER["standard_parallel_1",0],PARAMETER["latitude_of_origin",0],PARAMETER["ce
> ntral_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",
> 0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=merc+a=6378137 +b=6378137
> +units=m+nadgri... at null +wktext  +no_defs"]]
> Maybe anyone can help me or can tell me another strategy?
> thanks in advance,
> Marco
> http://osgeo-org.1803224.n2.nabble.com/Failed-to-initialize-PROJ-4-with-tp
> 6749580p6749580.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
