[gdal-dev] Failed to initialize PROJ.4 with ...
Jean-Claude Repetto
jrepetto at free.fr
Thu Sep 1 09:02:41 EDT 2011
Le 01/09/2011 12:32, Marco Scheuble a écrit :
> GDAL 1.4.4 doesn't support EPSG:900913, so I added the following lines to
> 'cubewerx_extra.wkt':
> # EPSG:900913
> 900913,PROJCS["Google Maps Global
> Mercator",GEOGCS["WGS84",DATUM["WGS_1984",SPHEROID["WGS84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Mercator_2SP"],PARAMETER["standard_parallel_1",0],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=merc+a=6378137
> +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
> +units=m+nadgri... at null +wktext +no_defs"]]
EPSG:900913 is deprecated since many years, use EPSG:3857 instead.
Jean-Claude
