[gdal-dev] Using GDAL to update DBFs of an ESRI Shapefile ?
Even Rouault
even.rouault at mines-paris.org
Thu Sep 1 13:49:52 EDT 2011
Le jeudi 01 septembre 2011 19:29:58, vasile a écrit :
> I failed in finding a programatic way of updating the attributes of an ESRI
> Shapefile feature (using Ruby 1.9.x on OSX Lion) therefore I wonder if I
> can use GDAL to accomplish this task.
> Let's say I have a CSV file containing the fields/rows that I want to
> update and an ESRI shapefile with the associated .dbf. Basically I want to
> update only the DB with the content from CSV. Is it possible ?
Yes, the shapefile driver supports editing both the geometry and attributes of
an existing datasource. Not sure about the state of Ruby bindings to do that
(they lack a dedicated maintainer), but you could certainly accompish that
with C, C++, Java, C#, Perl or Python.
Your friends are the Feature.SetField() and Layer.SetFeature() methods.
> Thanks,
> http://osgeo-org.1803224.n2.nabble.com/Using-GDAL-to-update-DBFs-of-an-ESR
> I-Shapefile-tp6750885p6750885.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
