[gdal-dev] gdal/ogr version (was NotImplementedError: Wrong
number...)
Marius Jigmond
mariusjigmond at hotmail.com
Thu Sep 1 21:52:30 EDT 2011
On 09/01/2011 08:23 PM, Ole Nielsen wrote:
> Many thanks for the reply, but I need the Python bindings as we are
> using ogr deeply embedded in an application and creating of new layers
> using the SetField command (amongst others) is critical. Hence my
> worry when we get the error
> NotImplementedError: Wrong number of arguments for overloaded function
> 'Feature_SetField'.
> I am sure it is something simple that changed in more recent versions
> - such as an extra required argument perhaps - and I'd be grateful if
> someone who knows the codebase could tell me what this error means and
> what I must do to make the call succeed.
> Many thanks
> Ole Nielsen
> On Fri, Sep 2, 2011 at 8:15 AM, Eli Adam <EAdam at co.lincoln.or.us
> <mailto:EAdam at co.lincoln.or.us>> wrote:
> Ole,
> > Is there a way of telling which one I am using (both when running
> > commandline org2org and when importing the ogr module in python)?
> ogr2ogr --version will work on the command line for at least the
> major version number. I'm not sure about in python.
This should give you the bindings version picked up by Python:
>>>from osgeo import gdal
>>>gdal.__version__
You can also check the PYTHONPATH with
>>>import sys
>>>sys.path
to see which location gets picked up first when you import osgeo modules
likely locations you'll find the modules:
/usr/(local)/lib/python2.x/dist-packages
-marius
> HTH, Eli
> > Cheers and thanks
> > Ole
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110901/79d18f3c/attachment.html
