[gdal-dev] RE: GDALWARP Chunk Problem (Tiling Effect)
heng.feng
heng.feng at aircominternational.com
Fri Sep 2 03:20:21 EDT 2011
The -r cubic option seems to be working like a charm. Thanks a lot for your
suggestion, Brian.
However, I am still not quite sure why this tiling effect occurred when
using the default resampling method (i.e. nearest neighbour ) on this map
data. And how can we tell what kind of resampling method should be used on a
particular map data?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDALWARP-Chunk-Problem-Tiling-Effect-tp6749055p6752965.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
