[gdal-dev] Merging tiff4 files
aperi2007
aperi2007 at gmail.com
Mon Sep 5 03:55:52 EDT 2011
I'm try-ing to merge some tiff4 raster.
The call I'm using (thx Frank and Etienne) is these:
python gdal_merge.py -o ../raster/raster_1.tif -n 0 -ot Byte -pct
../raster/raster_1/*.tif
gdal_translate -co NBITS=1 -co COMPRESS=CCITTFAX4 -co TFW=YES
../raster/raster_1.tif ../raster/raster_2.tif
I firstly merge they with gdal_merge.py and after I translate they in a
CTTIFF4 1 bit color.
On a little test it work very well.
But when I apply it to all set of raster it give me this memory error.
D:\_fusion_raster_bw\gdal64bit>python gdal_merge.py -o
../raster/livorno0.tif -n
0 -ot Byte -pct ../raster/livorno/*.tif
0...10Traceback (most recent call last):
File "gdal_merge.py", line 513, in <module>
sys.exit(main())
File "gdal_merge.py", line 499, in main
fi.copy_into( t_fh, band, band, nodata )
File "gdal_merge.py", line 242, in copy_into
nodata_arg )
File "gdal_merge.py", line 62, in raster_copy
nodata )
File "gdal_merge.py", line 102, in raster_copy_with_nodata
to_write = Numeric.choose( nodata_test, (data_src, data_dst) )
File
"C:\OSGeo4W\apps\Python25\lib\site-packages\numpy\core\fromnumeric.py", l
ine 170, in choose
return choose(choices, out=out, mode=mode)
MemoryError
I don't know if this is a know issue or a problem of python configuration.
I'm working on a windows7 64 bit, and I'm using a gdal 64bit version.
Andrea Peri
qwerty àèìòù
