[gdal-dev] ECW writing (was GTiff optimisation)
Jean-Claude Repetto
jrepetto at free.fr
Mon Sep 5 09:51:05 EDT 2011
Le 01/09/2011 14:12, Even Rouault a écrit :
>> Le jeudi 01 septembre 2011 01:56:04, Pinner, Luke a écrit :
>>> Does this apply to the 4.x read-only version of the ERDAS ECW/JP2 SDK as
>>> well as the old 3.3 SDK?
> I've just commited a new changeset. Now the support for updating the header info
> has been successfully tested on Linux 64bit with 3.3 SDK, Windows 32bit with 3.3
> SDK and Windows 32bit with 4.2 Read-Only SDK.
I have a problem related to this change.
I have downloaded the SVN version of GDAL, and tried to compile it. But
it fails:
/bin/sh /home/jcr/gdal/libtool --mode=link g++ gdalinfo.lo
/home/jcr/gdal/libgdal.la -o gdalinfo
libtool: link: g++ .libs/gdalinfo.o -o .libs/gdalinfo
/home/jcr/gdal/.libs/libgdal.so -L/usr/lib64
-L/usr/lib64/postgresql-9.0/lib64 -lgeos_c /usr/lib64/libsqlite3.so
/usr/lib64/libexpat.so /usr/lib64/libNCSEcw.so /usr/lib64/libNCSCnet.so
/usr/lib64/libNCSUtil.so -lgif /usr/lib64/libgeotiff.so
/usr/lib64/libproj.so -lm -ljpeg -ltiff -lpng -lpq -lpthread -lcurl -lrt
-lssl -lcrypto /usr/lib64/libgmp.so -ldl -lz
/home/jcr/gdal/.libs/libgdal.so: undefined reference to `NCSEcwEditReadInfo'
`NCSEcwEditWriteInfo'
/home/jcr/gdal/.libs/libgdal.so: undefined reference to `NCSEcwEditFreeInfo'
collect2: ld returned 1 exit status
If I add the libNCSEcwC.so library, it works:
g++ .libs/gdalinfo.o -o .libs/gdalinfo /home/jcr/gdal/.libs/libgdal.so
-L/usr/lib64 -L/usr/lib64/postgresql-9.0/lib64 -lgeos_c
/usr/lib64/libsqlite3.so /usr/lib64/libexpat.so /usr/lib64/libNCSEcw.so
/usr/lib64/libNCSEcwC.so /usr/lib64/libNCSCnet.so
I am using libecwj2-3.3 on Linux 64 bits (Gentoo).
Jean-Claude
