[gdal-dev] adding georeferencing information
Brent Fraser
bfraser at geoanalytic.com
Mon Sep 5 11:53:26 EDT 2011
Jan,
I use:
listgeo mygeotiff.tif > mygeotiff.gtt
geotifcp -g mygeotiff.gtt nogeotags.tif mynewgeotiff.tif
FYI, I've been experimenting with GDAL's vrt format to sharpen my tiffs:
<VRTDataset rasterXSize="2890" rasterYSize="3451">
<VRTRasterBand dataType="Byte" band="1">
<Metadata />
<ColorInterp>Red</ColorInterp>
<KernelFilteredSource>
<SourceFilename relativeToVRT="1">NRT_123.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="2890" RasterYSize="3451" DataType="Byte"
BlockXSize="2890" BlockYSize="1" />
<SrcRect xOff="0" yOff="0" xSize="2890" ySize="3451" />
<DstRect xOff="0" yOff="0" xSize="2890" ySize="3451" />
<Kernel>
<Size>3</Size>
<Coefs>-0.111 -0.111 -0.111 -0.111 2 -0.111 -0.111 -0.111 -0.111</Coefs>
</Kernel>
</KernelFilteredSource>
</VRTRasterBand>
</VRTDataset>
My kernel tends to brighten the image a little (note the "2" in the
kernel) as well as sharpen. To try it on your file, create a VRT file
with gdal_translate -of VRT, then use a text editor to change the
SimpleSource tags to KernelFilteredSource and add the Kernel. You can
then create a sharpened tif by using the VRT as input to gdal_translate,
os simply open the VRT in Quantum GIS to view the results.
Best Regards,
Brent Fraser
On 9/5/2011 8:46 AM, Jan Hartmann wrote:
> Hi all,
> Is there a quick way to add back georeferencing information to a
> geotif file that has been processed by Imagemagick? I have lots of
> georeferenced images that I want to sharpen up a bit, but ImageMagick
> throws the georeference headers away. Is there a way to transport them
> from the original file to the derived one?
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110905/49b254b3/attachment.html
