[gdal-dev] Merging tiff4 files
aperi2007 aperi2007 at gmail.com
Mon Sep 5 14:08:03 EDT 2011
 > Are you sure you are using a 64bit GDAL ? AFAIR, OSGeo4W is 32bit only.
Thx for response.
I download the gdal 64bit version.
explode it on a single folder.
I use osgeo shell only as environment for python and go in the folder
gdal64 to call its gdal_merge.py.
I guess the libraries used was from gdal64,
but effectively the memory issue is on numpy, a python element
 > Anyway, it is known that gdal_merge.py is limited by memory in the
 >way it
 > operates. You might want to use gdalwarp or gdalbuildvrt in that case.
Unfortunately gdalbuildvrt is not useful for my need.
I need to produce 1 really physical raster.
But gdalwarp is a tool I never will think to use for this.
Is gdalwarp capable to merge raster ?
Thx,
Il 05/09/2011 19:24, Even Rouault ha scritto:
> Le lundi 05 septembre 2011 09:55:52, aperi2007 a écrit :
>> Hi,
>> I'm try-ing to merge some tiff4 raster.
>> The call I'm using (thx Frank and Etienne) is these:
>> python gdal_merge.py -o ../raster/raster_1.tif -n 0 -ot Byte -pct
>> ../raster/raster_1/*.tif
>> gdal_translate -co NBITS=1 -co COMPRESS=CCITTFAX4 -co TFW=YES
>> ../raster/raster_1.tif ../raster/raster_2.tif
>> I firstly merge they with gdal_merge.py and after I translate they in a
>> CTTIFF4 1 bit color.
>> On a little test it work very well.
>> But when I apply it to all set of raster it give me this memory error.
>> D:\_fusion_raster_bw\gdal64bit>python gdal_merge.py -o
>> ../raster/livorno0.tif -n
>>    0 -ot Byte -pct ../raster/livorno/*.tif
>> 0...10Traceback (most recent call last):
>>     File "gdal_merge.py", line 513, in<module>
>>       sys.exit(main())
>>     File "gdal_merge.py", line 499, in main
>>       fi.copy_into( t_fh, band, band, nodata )
>>     File "gdal_merge.py", line 242, in copy_into
>>       nodata_arg )
>>     File "gdal_merge.py", line 62, in raster_copy
>>       nodata )
>>     File "gdal_merge.py", line 102, in raster_copy_with_nodata
>>       to_write = Numeric.choose( nodata_test, (data_src, data_dst) )
>>     File
>> "C:\OSGeo4W\apps\Python25\lib\site-packages\numpy\core\fromnumeric.py", l
>> ine 170, in choose
>>       return choose(choices, out=out, mode=mode)
>> MemoryError
>> I don't know if this is a know issue or a problem of python configuration.
>> I'm working on a windows7 64 bit, and I'm using a gdal 64bit version.
> Anyway, it is known that gdal_merge.py is limited by memory in the way it
