[gdal-dev] ECW writing (was GTiff optimisation)
Jean-Claude Repetto
jrepetto at free.fr
Tue Sep 6 08:40:07 EDT 2011
Le 06/09/2011 14:12, Even Rouault a écrit :
> I believe this should be fixed now by http://trac.osgeo.org/gdal/changeset/23067
> The case that was dealt with before was when using ./configure
> --with-ecw=/the/path/to/install/dir , but not ./configure --with-ecw[=yes]
> which, I presume, is your use case.
> Please confirm if it works for you.
It works now, thanks.
For your information, I have used ./configure without any parameter,
because the script is able to detect if the libecwj2 library is
installed or not.
Now I am going to test gdal_edit.py .
Jean-Claude
