[gdal-dev] Fwd: NotImplementedError: Wrong number of arguments
for overloaded function 'Feature_SetField'.
Ole Nielsen
ole.moller.nielsen at gmail.com
Tue Sep 6 10:51:55 EDT 2011
Thanks - I was hoping I could rely on the library to do the intelligent
truncation, but couldn't work it out.
Can I just clarify that the name to use with SetField would then be what is
provided by your last line?
layer_defn.GetFieldDefn(last_field_idx).GetNameRef()
Cheers and thanks
Ole
On Tue, Sep 6, 2011 at 9:26 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Ole Nielsen <ole.moller.nielsen at gmail.com>:
> > Hi Even
> > Thanks again for all your help - all tests now pass using either gdal 1.6
> or
> > 1.8. Just to summarise, there were three issues as I see them:
> > 1. Bounding boxes for raster data are computed differently (but
> better)
> > in newer versions
> Specific to PixelIsPoint in the GTiff driver.
> > 2. While v1.6 of ogre would allow an single number of type
> numpy.ndarray
> > this is no longer allow. Casting it to a float solves the problem.
> I wasn't aware it could work before. There's perhaps now an ambiguity on
> which
> method to use, due to the addition of new possibilities for SetField()
> (just a
> bling guess).
> > 3. New versions of ogre will not allow attribute names of length
> longer
> > than 10 (at least when using the ESRI driver). Formerly, I think it
> > silently
> > truncated, now it is up to the user. That's at least what I did.
> I've a looked quickly a bit at your code and I've the feeling that you
> truncate
> yourself, instead of relying on OGR. The Shapefile driver does more than
> truncating. It also ensures uniqueness of the truncated names. For example,
> if
> you try creating "a_very_long_name" and "a_very_long_name_again", they will
> be
> respectively truncated to "a_very_lon" and "a_very_l_1". A safer solution
> to get
> the field name that got to the file would be to :
> field_defn = ogr.FieldDefn("a_very_long_name", ogr.OFTString)
> lyr.CreateField(field_defn)
> layer_defn = lyr.GetLayerDefn()
> last_field_idx = layer_defn.GetFieldCount() - 1
> real_field_name = layer_defn.GetFieldDefn(last_field_idx).GetNameRef()
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110906/898c5104/attachment.html
