[gdal-dev] Unicode support in OGR Shape/DBF
Hilda Villegas
hilda.villegas at navico.com
Tue Sep 6 13:42:18 EDT 2011
I'm trying to use the preliminary encoding support for shapefile/dbf as
you said in the Ticket #882, SHAPE_ENCODING configuration variable can
be used to override the interpretation, but I cannot find the valid
values for this SHAPE_ENCODING anywhere, What value should I use if I
want to write Unicode characters (UTF-8) in the DBF?
Regards,
Hilda Villegas | r&D design engineer | NAVICO ENSENADA
Av. Reforma 1648 Fracc. Valle Verde | Ensenada, B.C. 22839 MX | Web:
www.navico.com <http://www.navico.com>
Tel: +52 646/175.1100 | Fax: +52 646/175.1196 | Mob: +52 1 646/197.0637
Confidentiality Notice | This message may contain confidential and/or
privileged information. If you are not the addressee or authorized to
receive this for the addressee, you must not use, copy, disclose or take
any action based on this message or any information herein. If you have
received this message in error, please advise the sender immediately by
reply e-mail and delete this message. Thank you for your cooperation.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110906/a4f8b73c/attachment-0001.html
