[gdal-dev] Codepage trouble with ogr2ogr from csv into Spatialite
Even Rouault
even.rouault at mines-paris.org
Wed Sep 7 14:02:49 EDT 2011
Le mercredi 07 septembre 2011 18:34:14, Jukka Rahkonen a écrit :
> I tried to convert data from text file into Spatialite through VRT file.
> Everything goes otherwise OK but the non-ASCII characters in the original
> text do not convert correctly. I am on Windows and the text file is using
> Windows Latin 1 encoding. I haven't found a place to give codepage in any
> of the VTR, CSV, or SQLite drivers. Is there any other way to get the
> characters right than convert CSV first into shapefiles and use
> Spatialite tools for importing them finally into Spatialite?
UTF-8 is considered as being the pivot encoding, so I don't see any choice
than using shapefiles for doing recoding. Perhaps we could have an option in
ogr2ogr to do user-specified recoding on the fly, for example -s_encoding -
t_encoding parameters ...
If you use GDAL trunk, you could set the SHAPE_ENCODING configuration option of
the shapefile driver to an empty string, so as no recoding occurs.
ogr2ogr out.shp in.vrt --config SHAPE_ENCODING ""
When reading out.shp, OGR will transcode from the default shapefile encoding,
which it interprets as being Latin1, to the OGR pivot encoding which is UTF-8,
which is probably what expects Spatialite.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
