[gdal-dev] Redirect CPLDebug output?
Jim Pendleton
jimp at ittvis.com
Thu Sep 8 17:46:23 EDT 2011
> Frank Warmerdam <warmerdam <at> pobox.com> writes:
> Ah yes, that does make it more complicated. I'm not sure of a good
> way to have something done automatically at library load time.
There's a JNI_OnLoad function that Java attempts to locate and execute
when it loads a new .so file.
I've seen the messages for this in LogCat, but I've not used it. It
seems a likely a candidate for GDAL-as-library initialization calls.
Thanks again for your help,
Jim P.
