[gdal-dev] Can't find a way of properly warping into a buffer
Daniele Tessaro
danielet at toonz.com
Mon Sep 12 13:24:15 EDT 2011
Hello everybody,
I'm really sorry if this post will be very long, but I swear I've
spent a lot of time (days!)
in trying to exactly understand this, also reading the sourcecode, but
I'm a little bit stuck!
In my application I need to read data from a srtm90 tif file
of extension 5 lat * 5 lon put in a raster of 6000x6000
pixels, 2 bytes per pixel. This data will then be used as a heightmap
texture for terrain rendering.
I have no problems in reading data using RasterIO function, I can also
keep 72mb of raster data in system memory performing only
one IO operation (so that I don't have to mess with async operations) but:
1. I can't keep a 72MB texture in video memory (but the whole terrain
extension should be
rendered if the viewer is high enough), so I have to read a resampled
lower resolution versions of the full terrain.
(Actually more than one depending on the height of the viewpoint),
and a full resolution version of a small piece of terrain that must be
updated fast(only for small rectangular chunks)
almost every time the user moves on the terrain.
2. I'll map my terrain on a plane. This means that I need to transform
data to some
projected coordinate system. Suppose UTM, with the proper zone (I don't mind the
deformations at the borders...).
Calling RasterIO in the proper way would solve problem 1, as it is
exposing exactly the interface I need.
The big issue is that it would be performing IO operations all the
time, while I want to perform
1 single IO operation and then resample on that data.
So first question: Is there a way of telling RasterIO to completely
cache data and never access disk?
RasterIO would not solve problem 2, as I would get unprojected data as result,
unless I get unprojected data and then I execute the projection.
I don't think it's the correct approach, also because RasterIO only
allows me only to read unprojected rectangular data,
while I want to read projected rectangular data that would become
trapezoidal if unprojected.
I've also spent time with the Warping functions, but I can't figure
out how to perform what I need.
For what I've seen I should initialize a GDALWarpOperation with
GDALWarpOptions so that:
- hSrcDS is my source dataset
- hDstDS is NULL, cause I want to warp to a buffer
- pfnTransformer must be set so that it can map from pixel / line
unprojected to pixel / line projected. I can use
GDALCreateGenImgProjTransformer but I have no destination dataset so
I can't figure out how to set it up.
Then I can't exactly understand the WarpRegionToBuffer API.
Suppose I need to sample in an output buffer of size W x H a region
that in the projected coordinate system (so after the transform)
is of size A x B. How should I set nDstXSize and nDstYSize? I would
expect being able to specify both those couples of params because
I should be able to get any region and to put it in any buffer
performing the appropriate resampling. But that function is a little
bit confusing
me.
can anyone help me?:-)
thanks
