[gdal-dev] mapfile config options - scan directory
Frank Warmerdam
warmerdam at pobox.com
Tue Sep 20 10:41:45 EDT 2011
On 11-09-20 05:47 AM, Travis Kirstine wrote:
> Hi All,
> I saw Frank's GDAL performance tips presentation at FOSS4G and he
> mentioned that a config option in a MS mapfile could be set to stop
> GDAL from scanning for auxiliary files when using external tiling. I
> have looked around in the MS documentation and GDAL and cannot find
> the option. If this option was set would it stop GDAL from using
> external worldfiles / overviews?
Travis,
The config option is documented at:
http://trac.osgeo.org/gdal/wiki/ConfigOptions#GDAL_DISABLE_READDIR_ON_OPEN
In MapServer you could add a line in the MAP object with:
CONFIG "GDAL_DISABLE_READDIR_ON_OPEN" "ON"
This will not prevent finding world files and overviews. It just means that
searching for them will require an active probe of the file system instead
of just consulting a loaded file list.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush | Geospatial Software Developer
