[gdal-dev] Ogr2Ogr Interlis1 Export
BSAP ( Andres Thomas )
thomas.andres at bsap.ch
Tue Sep 20 11:13:28 EDT 2011
--- Anyway, it's better to not rely on field order.
ITF and ILI go always together… when I give them to someone else, the attribute order has to correspond, because they using programs who looks to the ILI attribute order to import the ITF data
On Tue, Sep 20, 2011 at 8:16 PM, BSAP ( Andres Thomas ) <thomas.andres at bsap.ch> wrote:
… i’ve tried, but there are several tables to be exported…. I can’t write –select table1.fid,table1.color,table2.fid,table2.mysize,etc…
When I query one table with ogrinfo I see, that the attributes are listed in the same order like in the created ITF… if I only could change this…
Von: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
Gesendet: Dienstag, 20. September 2011 16:11
An: BSAP ( Andres Thomas )
Cc: gdal-dev at lists.osgeo.org
Betreff: Re: [gdal-dev] Ogr2Ogr Interlis1 Export
Thomas,
OGR doesn't promise the same field order. Individual drivers can reorder the fields when they save the data.
You may be able to reorder the fields using the -select option in ogr2ogr.
On Tue, Sep 20, 2011 at 7:05 PM, BSAP ( Andres Thomas ) <thomas.andres at bsap.ch> wrote:
Dear List,
i have exported data from postgres to an itf with the following command:
ogr2ogr -f "Interlis 1" mynew.itf,myili1.ili PG:"dbname='mydatabase' host='localhost' port='123' user='postgres' password='mypassword'"
The ITF was created, but the attributes of one table i.e. are not in the same order like in the ILI-File… and also not in the same order like in the Postgres Database…
Why that?
Thx for your help,
Thomas Andres
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584 <tel:%2B91-9494447584>
17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110920/1586cc18/attachment-0001.html
