[gdal-dev] PostgreSQL
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Sep 22 13:48:00 EDT 2011
Andy,
Send me the problematic shapefiles and explain what conversions you are
trying to perform.
On Thu, Sep 22, 2011 at 9:18 PM, Andy Colson <andy at squeakycode.net> wrote:
> Hi List,
> I'm using ogr2ogr to convert (and reproject) data from shapefile to PG, if
> I use insert statements the null dates are not a problem, but if I set
> PG_USE_COPY=YES, then I get errors:
> ERROR 1: COPY statement failed.
> ERROR: date/time field value out of range: "0000/00/00"
> CONTEXT: COPY parcelannov2, line 18, column recorded: "0000/00/00"
> Inserts are really slow, so I'd love to use copy instead.
> On another layer, regardless of insert/copy, I'm getting:
> ERROR: numeric field overflow
> DETAIL: A field with precision 19, scale 11 must round to an absolute
> value less than 10^8.
> CONTEXT: COPY poltwppoly, line 1, column shape_area:
> "1005965403.24000000954"
> I'm using: GDAL 1.9dev, released 2011/01/18
> I can make the shapefiles available if it would be of help. Is there
> anything else I can do/try/offer?
> Thanks,
> -Andy
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110922/ab4d0880/attachment.html
