[gdal-dev] OGR SQL implicit conversions
Daniel Morissette
dmorissette at mapgears.com
Thu Sep 22 15:07:38 EDT 2011
No strong opinion/preference for me...
On 11-09-21 01:20 PM, Tamas Szekeres wrote:
> Hi Devs,
> We have some problems due to the recent changes in the SQL expression
> parser which is related to the change in the implicit type conversion
> behaviour.
> Formerly we could safely use the following statement:
> select * from mytable where ogr_fid in ('1100','1101','1102')
> If the data type of ogr_fid is an integer or float then the expression
> evaluator has converted the string constants to numeric values implicitly.
> As of 1.8 the parser reports an error due to the incompatible types in
> the expression.
> I've added a ticket #4259 <http://trac.osgeo.org/gdal/ticket/4259>
> related to this problem including a patch to handle these string to
> numeric conversions.
> However I'm a bit uncertain whether some other conversions should also
> be supported or not. Having a larger number of conversion rules we might
> probably think about rewriting the current approach by using a more
> generic implementation.
> Any ideas?
> Best regards,
> Tamas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
