[gdal-dev] Problems with building GDAL 1.9 on Windows with MS VC
2008 and OSGeo4W
Alexander Bruy
alexander.bruy at gmail.com
Sat Sep 24 08:01:35 EDT 2011
Hi all,
I'm trying to build GDAL trunk on Windows XP SP3 using dependencies
from OSGeo4W with
MS VS Express 2008 SP1 (MS Platform SDK for Windows Server 2003 R2
installed too).
I install all necessary packages from OSGeo4W, checkout latest GDAL
sources (r23115) then
edit nmake.opt file and specify paths for dependensies libs.
When I run nmake /f makefile.vc in Visual Studio command prompt I get
next errors:
D:\devel\gdal\trunk>nmake /f makefile.vc
Microsoft (R) Program Maintenance Utility Version 7.00.8882
Copyright (C) Microsoft Corp 1988-2000. All rights reserved.
cd port
nmake /nologo /f makefile.vc
cl /nologo /MD /EHsc /Ox /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_D
EPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275 /wd4786 /wd4100 /wd4245 /wd4206 /w
d4018 /wd4389 -I..\port -I..\ogr -I..\gcore -I..\alg -I..\ogr\ogrsf_frmts -I..\
frmts\zlib -DHAVE_LIBZ -DHAVE_CURL -IC:\OSGeo4W/include/curl -DOGR_ENABLED /c
cpl_conv.cpp
cpl_conv.cpp
d:\devel\gdal\trunk\port\cpl_port.h(189) : warning C4005: 'VSI_LARGE_API_SUPPORT
ED' : macro redefinition
d:\devel\gdal\trunk\port\cpl_config.h(185) : see previous definition of
'VSI_LARGE_API_SUPPORTED'
cpl_conv.cpp(1271) : error C3861: 'snprintf': identifier not found
cpl_conv.cpp(2377) : error C2079: 'sStatBuf' uses undefined struct 'stat64'
cpl_conv.cpp(2379) : error C2664: 'VSIStatL' : cannot convert parameter 2 from '
int *' to 'VSIStatBufL *'
Types pointed to are unrelated; conversion requires reinterpret_cast, C-
style cast or function-style cast
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Platform SDK for Windows
Server 2003 R2\Bin\nmake.exe"' : return code '0x2'
Stop.
In same time I can compile GDAL 1.8.1 using same paths in nmake.opt
file without any
errors. Any ideas?
Thanks
Alexander Bruy
