[gdal-dev] Problem with type of data in ESRI SHAPEFILE
Frank Warmerdam
warmerdam at pobox.com
Mon Sep 26 12:22:03 EDT 2011
Guilhain,
The problem is that you aren't setting the precison when you create
the new fields, so it is defaulting to precision zero (integer).
You will need a call something like:
newField.SetPrecision( 11 )
Best regards,
On Mon, Sep 26, 2011 at 9:09 AM, Guilhain Averlant <g.averlant at gmail.com> wrote:
> Hi Everyone
> I'm writting a litte script that order points coordinates.
> But I don't know why but I have a problem when my script rebuild data
> associated to geometries.
> In fact I have a field in REAL who is in my new shapefile well-respected in
> Real too, but data are writting in integer...
> Do you have a solution ?
> Configuration :
> Python 2.6
> GDAL 1.8.0
> I try whit python 2.7 and GDAL 1.8.1 but the problem is still here.
> Guilhain
> PS : Script and data are attached to this email.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
