[gdal-dev] PostgreSQL
Andy Colson
andy at squeakycode.net
Wed Sep 28 10:49:47 EDT 2011
Sorry to keep pestering. Is there a better place I should be seeking
help? Would a $bounty$ help?
-Andy
On 9/22/2011 10:48 AM, Andy Colson wrote:
> Hi List,
> I'm using ogr2ogr to convert (and reproject) data from shapefile to PG,
> if I use insert statements the null dates are not a problem, but if I
> set PG_USE_COPY=YES, then I get errors:
> ERROR 1: COPY statement failed.
> ERROR: date/time field value out of range: "0000/00/00"
> CONTEXT: COPY parcelannov2, line 18, column recorded: "0000/00/00"
> Inserts are really slow, so I'd love to use copy instead.
> On another layer, regardless of insert/copy, I'm getting:
> ERROR: numeric field overflow
> DETAIL: A field with precision 19, scale 11 must round to an absolute
> value less than 10^8.
> CONTEXT: COPY poltwppoly, line 1, column shape_area:
> "1005965403.24000000954"
> I'm using: GDAL 1.9dev, released 2011/01/18
> I can make the shapefiles available if it would be of help. Is there
> anything else I can do/try/offer?
> Thanks,
> -Andy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
