[gdal-dev] PostgreSQL
Andy Colson
andy at squeakycode.net
Wed Sep 28 11:09:00 EDT 2011
They use a slightly older version of shapelib that doesnt quite work
with null's. If I ogr2ogr shapefile -> shapefile (to get it in the
projection I want), then shp2pgsql will fail with fields that are null.
Which, I could to ask them to update, yes. It was a 50/50. Ask gdal or
ask postgis.
-Andy
On 9/28/2011 9:53 AM, Ivan Price wrote:
> is there a reason you don't want to use shp2pgsql ?
> not sure if its better for everything but i've used it on occasion when i had a prob in ogr2ogr
> -i
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Andy Colson
> Envoyé : Wednesday, 28 September 2011 4:50 PM
> À : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] PostgreSQL
> Sorry to keep pestering. Is there a better place I should be seeking help? Would a $bounty$ help?
> -Andy
> On 9/22/2011 10:48 AM, Andy Colson wrote:
>> Hi List,
>> I'm using ogr2ogr to convert (and reproject) data from shapefile to
>> PG, if I use insert statements the null dates are not a problem, but
>> if I set PG_USE_COPY=YES, then I get errors:
>> ERROR 1: COPY statement failed.
>> ERROR: date/time field value out of range: "0000/00/00"
>> CONTEXT: COPY parcelannov2, line 18, column recorded: "0000/00/00"
>> Inserts are really slow, so I'd love to use copy instead.
>> On another layer, regardless of insert/copy, I'm getting:
>> ERROR: numeric field overflow
>> DETAIL: A field with precision 19, scale 11 must round to an absolute
>> value less than 10^8.
>> CONTEXT: COPY poltwppoly, line 1, column shape_area:
>> "1005965403.24000000954"
>> I'm using: GDAL 1.9dev, released 2011/01/18
>> I can make the shapefiles available if it would be of help. Is there
>> anything else I can do/try/offer?
>> Thanks,
>> -Andy
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
