[gdal-dev] EPSG 7.9 Upgrade in Trunk
Even Rouault
even.rouault at mines-paris.org
Thu Sep 29 03:54:32 EDT 2011
Selon Frank Warmerdam <warmerdam at pobox.com>:
Frank,
There might be further actions needed as far as GDAL (and libgeotiff perhaps ?)
is concerned according to ticket http://trac.osgeo.org/gdal/ticket/4223 : "Next
time the EPSG database is updated, note that a Krovak parameter has been renamed
(and renumbered)."
Best regards,
Even
> Folks,
> I have upgraded libgeotiff, PROJ.4 and GDAL with EPSG definitions regenerated
> from the EPSG 7.9 database. New "preferred datum shift selection" rules are
> also in place which will give preference to 7 parameter datum shifts over
> 3 parameter datum shifts are also in place causing a fair amount of churn
> in the definitions.
> The updates are in "trunk" for each of the projects. I plan to produce
> libgeotiff and PROJ.4 release candidates soon with the new definitions
> so if you think you might have objections please investigate and speak
> up promptly.
