[gdal-dev] Identify EPSG SRS_ID from Shapefile SRS Definition
Tony.Na at sybase.com
Thu Sep 29 13:21:15 EDT 2011
Hi fellow GDAL/OGR developers,
I'm currently developing an OGR data provider module for Sybase SQLAnywhere
database, which recently supports spatial features in it's version 12
release. I have a question regarding the best way to evaluate the
equivalence between two Spatial Reference Systems. It seems to me that
when I use ogr2ogr to translate a SQLAnywhere Layer to a shapefile, the
shapefile data provider calls the morphToESRI() and morphFromESRI
functions, which strips out all Authority nodes from my original SRS WKT.
For example, for the SRS “NAD27 / Alaska Albers”, the WKT representation
before and after the morph follows:
Before morph:
PROJCS["Albers Equal Area",
GEOGCS["NAD27",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke 1866", 6378206.4, 294.978698213898,
AUTHORITY["EPSG","7008"]],
TOWGS84[-3,142,183,0,0,0,0],
AUTHORITY["EPSG","6267"]],
PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4267"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",55],
PARAMETER["standard_parallel_2",65],
PARAMETER["latitude_of_center",50],
PARAMETER["longitude_of_center",-154],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["us_survey_feet",0.3048006096012192],
AUTHORITY["EPSG","2964"]]
After morph:
PROJCS["Albers_Equal_Area",
GEOGCS["GCS_North_American_1927",
DATUM["D_North_American_1927",
SPHEROID["Clarke_1866",6378206.4,294.9786982]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Albers"],
PARAMETER["latitude_of_origin",50],
PARAMETER["central_meridian",-154],
,UNIT["Foot_US",0.30480060960121924]]
The problem arises when I try to use this exported shapefile as a source to
Ogr2ogr when creating a new SQLAnywhere layer, where I have to find the SRS
in our database. However, when I call the AutoIdentifyEPSG() function of
OGRSpatialReference system, I don’t get all the authority name and code
restored, here’s the resulting WKT for the above example:
After restore:
UNIT["Degree",0.017453292519943295],
My question is, what is the best way to test this WKT as the same SRS as my
original WKT, since the key identification AUTHORITY["EPSG","2964"]] is
missing from the root node. Thanks for your time.
Thanks,
- Tony Na
