[gdal-dev] gdal error in multi-core process
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Tue Apr 3 16:16:54 EDT 2012
Hi thanks
for the fast replay.
yes my mistake, there was the same temp.tif file in read/write from
the different processors.
Thanks
Ciao Ciao
> Giuseppe,
> You haven't offered too much detail of what myscript.sh does, but
> I'm guessing you use a fixed name for temporary files (ie. temp.tif)
> and you have two different scripts interfering with each other. Try
> embedding the script process id into the temporary file name or
> some similar approach to avoid conflicts.
> I don't think this is a GDAL problem.
> But, you might want to be aware that GDAL is not going to
> react well if you have multiple processes updating one output
> file.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
Giuseppe Amatulli
Web: www.spatial-ecology.net
